| New Tubedata for TV-7 (european tubes) | ||||||||||
| Tube Type | Fil. Voltage | Selector Positions | Bias | Shunt | Range | Press to Test | Minimum Value | Notations | ||
| 6550/KT88 | 6,3 | HS5-3481 | 20 | 0 | D | 3 | 45 | |||
| 5U3C (Russ) | 5 | JS0-6000 | 0 | 40 | A | 7 | 45 | Diode #1 | ||
| 5U3C (Russ) | 5 | JS0-4000 | 0 | 40 | A | 7 | 45 | Diode #2 | ||
| 6C19 (Russ) | 6,3 | EV2-6090 | 50 | 0 | C | 3 | 60 | |||
| 6E5 - DDR | 6,3 | HS5-6080 | 0 | 100 | A | 3 | Eye open | |||
| 6E5 - DDR | 6,3 | HS5-6380 | 0 | 100 | A | 3 | Eye closed | |||
| 6E5 - Europe | 6,3 | HS5-4080 | 0 | 100 | A | 3 | Eye open | |||
| 6E5 - Europe | 6,3 | HS5-4380 | 0 | 100 | A | 3 | Eye closed | |||
| 6ME10 (Japan) | 6,3 | DU1-5270 | 0-100 | 100 | A | 3 | Bias controls eye open -> close | |||
| C3g | 6,3 | JR6-3472 | 15 | 0 | D | 3 | 50 | Meter reads 60 for new tube (best ever seen) | ||
| C3m | 20 | JR6-2473 | 20 | 0 | D | 3 | 30 | Meter reads 40 for new tube (best ever seen) | ||
| DL92 | 3 | BX3-2435 | 40 | 0 | C | 3 | 40 | |||
| EAM86 | 6,3 | EV8-7630 | 0-100 | 100 | A | 3 | Bias controls eye open -> close | |||
| EM71/72 | 6,3 | JR6-2570 | 0-100 | 100 | A | 3 | Bias controls eye open -> close | |||
| EM800 | 6,3 | EV1-6730 | 0-100 | 100 | A | 3 | Bias controls eye open -> close | |||
| EMM801 | 6,3 | EV7-2630 | 0-100 | 100 | A | 3 | Band left side, bias controls eye open -> close | |||
| EMM801 | 6,3 | EV7-2830 | 0-100 | 100 | A | 3 | Band right side, bias controls eye open -> close | |||
| EMM803 | 6,3 | EV3-6910 | 0-100 | 100 | A | 3 | Band, bias controls eye open -> close | |||
| EMM803 | 6,3 | EV3-6710 | 0 | 100 | A | 3 | Stereo-point | |||
| PABC80 | 10 | EV8-9070 | 11 | 0 | B | 3 | 30 | Triode section, set line adjust to 54 | ||
| PABC80 | 10 (Uf = 9,5V) | EV0-6070 | 0 | 0 | A | 2 | 40 | Diode #1, set line adjust to 54 | ||
| PABC80 | 10 | EV0-2030 | 0 | 70 | A | 2 | 40 | Diode #2, set line adjust to 54 | ||
| PABC80 | 10 | EV0-1070 | 0 | 70 | A | 2 | 40 | Diode #3, set line adjust to 54 | ||
| PC86 | 4,3 (Uf = 3,8V) | ET2-1030 | 15 | 0 | D | 3 | 50 | Set line adjust to 54 | ||
| PC88 | 4,3 (Uf = 3,8V) | ET1-8020 | 15 | 0 | D | 3 | 50 | Set line adjust to 54 | ||
| PC92 | 3 (Uf = 3,1V) | ET6-1070 | 15 | 0 | C | 3 | 50 | Set line adjust to 65 | ||
| PC96 | 3 (Uf = 3,1V) | ET1-7020 | 10 | 0 | B | 3 | 30 | |||
| PCC189 | 7,5 | EV2-1030 | 20 | 0 | D | 3 | 60 | System 1 | ||
| PCC189 | 7,5 | EV7-6080 | 20 | 0 | D | 3 | 60 | System 2 | ||
| PCC84 | 7,5 (Uf = 7,2V) | EV6-9080 | 25 | 0 | C | 3 | 50 | System 1, set line adjust to 58 | ||
| PCC84 | 7,5 | EV2-3010 | 25 | 0 | C | 3 | 50 | System 2, set line adjust to 58 | ||
| PCC85 | 10 (Uf = 9V) | EV2-1030 | 15 | 0 | C | 3 | 60 | System 1, set line adjust to 52 | ||
| PCC85 | 10 | EV7-6080 | 15 | 0 | C | 3 | 60 | System 2, set line adjust to 52 | ||
| PCC88 | 7,5 (Uf = 7V) | EV2-1030 | 15 | 0 | D | 3 | 60 | System 1, set line adjust to 55 | ||
| PCC88 | 7,5 | EV7-6080 | 15 | 0 | D | 3 | 60 | System 2, set line adjust to 55 | ||
| PCF801 | 10 (Uf = 8,5V) | EV9-8010 | 30 | 0 | D | 3 | 40 | Triode section, set line adjust to 50 | ||
| PCF801 | 10 | EV2-6710 | 20 | 0 | C | 3 | 40 | Pentode section, set line adjust to 50 | ||
| PCF82 | 10 (Uf = 9V) | EV9-1080 | 25 | 0 | C | 3 | 60 | Triode section, set line adjust to 54 | ||
| PCF82 | 10 | EV2-6370 | 20 | 0 | C | 3 | 40 | Pentode section, set line adjust to 54 | ||
| PCL805 | 20 (Uf = 17,5V) | EV2-1930 | 20 | 0 | C | 3 | 45 | Triode section, set line adjust to 50 | ||
| PCL805 | 20 | EV9-6780 | 20 | 0 | D | 3 | 40 | Pentode section, set line adjust to 50 | ||
| PCL82 | 20 (Uf = 16V) | EV1-9080 | 15 | 0 | B | 3 | 40 | Triode section, set line adjust to 50 | ||
| PCL82 | 20 | EV3-6720 | 30 | 0 | C | 3 | 60 | Pentode section, set line adjust to 50 | ||
| PCL84 | 20 (Uf = 15V) | EV1-2030 | 20 | 0 | B | 3 | 50 | Triode section, set line adjust to 46 | ||
| PCL84 | 20 | EV8-6970 | 20 | 0 | C | 3 | 50 | Pentode section, set line adjust to 46 | ||
| PCL86 | 12,6 (Uf = 13,5V) | EV1-9020 | 10 | 0 | C | 3 | 30 | Triode section, set line adjust to 64 | ||
| PCL86 | 12,6 | EV8-6370 | 20 | 0 | D | 3 | 40 | Pentode section, set line adjust to 64 | ||
| PL36 | 25 | CX5-2408 | 40 | 0 | D | 3 | 50 | Use cable to 'P' | ||
| PL805 | 20 (Uf = 17,5V) | EV1-6370 | 20 | 0 | D | 3 | 50 | Set line adjust to 50 | ||
| PL95 | 4,3 (Uf = 4,5V) | ET1-5632 | 20 | 0 | C | 3 | 40 | |||
| PM84 | 4,3 | EV1-6730 | 0-100 | 100 | A | 3 | Bias controls eye open -> close | |||
| PY88 | 25 (Uf = 30V) | EV0-0090 | 0 | 70 | A | see notations | 40 | Kathode topside! Hold down pushbutton 8-METER REV. and press pushbutton 7-RECT | ||
| UL84 | 50 (Uf = 45V) | EV2-7930 | 30 | 0 | D | 3 | 50 | |||
| UM4 | 12,6 | BY5-4370 | 0-100 | 0 | A | 3 | Right sytem - eye open, left system various with bias | |||
| UM4 | 12,6 | BY5-4670 | 0-100 | 0 | A | 3 | Left sytem - eye open, right system various with bias | |||
| UM80 | 20 (Uf = 19V) | EV1-9020 | 0-30 | 100 | A | 3 | Set line adjust to 56 | |||
| UY82 | 50 (Uf = 55V) | EV0-9030 | 0 | 40 | A | 7 | 40 | |||
| UY85 | 50 (Uf = 38V) | EV0-9030 | 0 | 40 | A | 7 | 40 | |||
| UCC85 | 25 | EV7-6089 | 10 | 0 | C | 3 | 54 | |||
| UCC85 | 25 | EV2-1039 | 10 | 0 | C | 3 | 54 | |||
