Tube type | Filament | Selectors | Bias | Shunt | Range | Press | Minimum value | Notations |
2FS5 | 2.5 | ET1-5670 | 10 | D | 3 | 30 | ||
2GK5 | 2.5 | ET2-5076 | 30 | C | 3 | 38 | ||
3AW3 | 3.0 | HS0-0000 | 0 | 62 | A | 4 | 40 | Cap connects to plate |
3BX6 | 3.0 | EV2-7819 | 13 | C | 3 | 38 | ||
3GK5 | 3.0 | ET2-5076 | 30 | C | 3 | 38 | ||
4AV6 | 4.3 | ET1-7025 | 12 | B | 3 | 32 | Triode Sect. | |
4AV6 | 4.3 | ET1-6025 | 0 | 0 | A | 2 | 40 | Diode No. 1 |
4AV6 | 4.3 | ET1-5027 | 0 | 0 | A | 2 | 40 | Diode No. 2 |
5CU4 | 5.0 | JS0-6010 | 0 | 70 | A | 7 | 32 | Plate No. 1 |
5CU4 | 5.0 | JS0-4010 | 0 | 70 | A | 7 | 32 | Plate No. 2 |
5EW6 | 5.0 | ET1-5627 | 26 | B | 3 | 52 | ||
6DG7 | 6.3 | EV2-7839 | 9 | C | 3 | 41 | ||
6DM4 | 6.3 | HY0-5030 | 0 | 38 | A | 7 | 50 | |
6DX8 | 6.3 | EV8-6970 | 10 | D | 3 | 47 | Pentode Sect. | |
6DX8 | 6.3 | EV1-2030 | 26 | B | 3 | 50 | Triode Sect. | |
6ET7 | 6.3 | EV7-9860 | 10 | D | 3 | 38 | Pentode Sect. | |
6ET7 | 6.3 | EV0-3010 | 0 | 0 | A | 2 | 20 | Diode No. 1 |
6ET7 | 6.3 | EV0-2010 | 0 | 0 | A | 2 | 20 | Diode No. 2 |
6FD6 | 6.3 | ET1-6572 | 20 | 20 | A | 2 | 44 | Make no gas test |
6FQ5A | 6.3 | ET2-5070 | 15 | D | 3 | 50 | ||
6FQ7 | 6.3 | EV7-6080 | 23 | B | 3 | 50 | Triode No. 1 | |
6FQ7 | 6.3 | EV2-1030 | 23 | B | 3 | 50 | Triode No. 2 | |
6GE8 | 6.3 | EV8-9170 | 27 | B | 3 | 29 | Pentode Sect. | |
6GE8 | 6.3 | EV3-6020 | 65 | C | 3 | 56 | Triode Sect. | |
6GK5 | 6.3 | ET2-5076 | 30 | C | 3 | 38 | ||
6GM5 | 6.3 | EV6-9170 | 10 | D | 3 | 36 | ||
6GM8 | 6.3 | EV7-6080 | 30 | 0 | A | 2 | 32 | Triode No. 1 - Make no gas test |
6GM8 | 6.3 | EV2-1030 | 30 | 0 | A | 2 | 32 | Triode No. 2 - Make no gas test |
6GX6 | 6.3 | ET1-5627 | 27 | B | 3 | 21 | ||
6GY6 | 6.3 | ET1-5627 | 28 | B | 3 | 20 | ||
6HB6 | 6.3 | EV2-7819 | 10 | E | 3 | 38 | ||
6HF8 | 6.3 | EV7-9860 | 10 | D | 3 | 35 | Pentode Sect. | |
6HF8 | 6.3 | EV2-3010 | 30 | B | 3 | 25 | Triode Sect. | |
8FQ7 | 7.5 | EV7-6080 | 23 | B | 3 | 50 | Triode No. 1 | |
8FQ7 | 7.5 | EV2-1030 | 23 | B | 3 | 50 | Triode No. 2 | |
10EM7 | 10.0 | HY4-5060 | 20 | B | 3 | 25 | Triode No. 1 | |
10EM7 | 10.0 | HY1-2030 | 60 | D | 3 | 35 | Triode No. 2 | |
10HF8 | 10.0 | EV7-9860 | 10 | D | 3 | 35 | Pentode Sect. | |
10HF8 | 10.0 | EV2-3010 | 30 | B | 3 | 25 | Triode Sect. | |
12AU8 | 12.6 | EV7-9860 | 10 | D | 3 | 30 | Pentode Sect. | |
12AU8 | 12.6 | EV2-3010 | 9 | D | 3 | 25 | Triode Sect. | |
12DM4 | 12.6 | HY0-5030 | 0 | 38 | A | 7 | 50 | |
12GW6 | 12.6 | HS5-0480 | 34 | D | (1) | 38 | Cap connects to plate | |
13FR7 | 12.6 | EV7-6080 | 20 | B | 3 | 25 | Triode No. 1 | |
13FR7 | 12.6 | EV3-1090 | 60 | D | 3 | 36 | Triode No. 2 | |
14JG8 | 12.6 | EV8-9070 | 10 | B | 3 | 38 | Triode Sect. | |
14JG8 | 12.6 | EV0-6010 | 0 | 70 | A | 2 | 40 | Diode No. 1 |
14JG8 | 12.6 | EV0-2030 | 0 | 70 | A | 2 | 40 | Diode No. 2 |
15EA7 | 12.6 | JX4-5060 | 10 | B | 3 | 39 | Triode No. 1 | |
15EA7 | 12.6 | JX1-2030 | 56 | D | 3 | 33 | Triode No. 2 | |
16A5 | 20.0 | EV2-7930 | 27 | C | 3 | 56 | Make line test at 50 | |
16A8 | 20.0 | EV3-6720 | 26 | C | 3 | 58 | Do. | |
16A8 | 20.0 | EV1-9080 | 21 | B | 3 | 23 | Do. | |
17DM4 | 20.0 | HY0-5030 | 0 | 38 | A | 7 | 50 | Make line test at 58 |
17GW6 | see data following tube type 7895 | |||||||
19EZ8 | 20.0 | EV9-8000 | 30 | B | 3 | 20 | Triode No. 1 | |
19EZ8 | 20.0 | EV7-6000 | 30 | B | 3 | 20 | Triode No. 2 | |
19EZ8 | 20.0 | EV2-3010 | 31 | B | 3 | 24 | Triode No. 3 | |
19HV8 | 20.0 | EV9-6780 | 10 | D | 3 | 22 | Pentode Sect. | |
19HV8 | 20.0 | EV1-2030 | 25 | B | 3 | 20 | Triode Sect. | |
20EZ7 | 20.0 | CR8-7090 | 12 | B | 3 | 32 | Triode No. 1 | |
20EZ7 | 20.0 | CR5-6040 | 12 | B | 3 | 32 | Triode No. 2 | |
25DK4 | 25.0 | ET0-5070 | 0 | 65 | A | 7 | 40 | |
40FR5 | 35.0 | ET2-7610 | 40 | C | 3 | 52 | ||
6267 | 6.3 | EV9-6138 | 28 | B | 3 | 18 | ||
6947 | 6.3 | DW7-8050 | 30 | B | 3 | 33 | Triode No. 1 | |
6947 | 6.3 | DW2-1040 | 30 | B | 3 | 33 | Triode No. 2 | |
6948 | 6.3 | DW7-8050 | 29 | B | 3 | 23 | Triode No. 1 | |
6948 | 6.3 | DW2-1040 | 29 | B | 3 | 23 | Triode No. 2 | |
7316 | 12.6 | EV7-6080 | 24 | B | 3 | 56 | Triode No. 1 | |
7316 | 12.6 | EV2-1030 | 24 | B | 3 | 56 | Triode No. 2 | |
7408 | 6.3 | HS5-3481 | 21 | C | 3 | 46 | ||
7587 | 6.3 | DR4-0280 | 10 | D | (1) | 38 | Cap=Plate. Use Hickok adapter 1050-127 | |
7693 | 6.3 | ET1-5627 | 15 | B | 3 | 50 | ||
7694 | 6.3 | ET1-5627 | 0 | C | 3 | 48 | ||
7719 | 12.6 | EV2-1030 | 38 | C | 3 | 14 | ||
7724 | 12.6 | EV8-9070 | 20 | B | 3 | 12 | Triode Sect. | |
7724 | 12.6 | EV0-2030 | 0 | 0 | A | 2 | 32 | Diode No. 1 |
7724 | 12.6 | EV0-6010 | 0 | 0 | A | 2 | 32 | Diode No. 2 |
7728 | 12.6 | EV7-6080 | 10 | C | 3 | 50 | Triode No. 1 | |
7728 | 12.6 | EV2-1030 | 10 | C | 3 | 50 | Triode No. 2 | |
7729 | 12.6 | EV7-6080 | 12 | B | 3 | 32 | Triode No. 1 | |
7729 | 12.6 | EV2-1030 | 12 | B | 3 | 32 | Triode No. 2 | |
7730 | 12.6 | EV7-6080 | 24 | B | 3 | 56 | Triode No. 1 | |
7730 | 12.6 | EV2-1030 | 24 | B | 3 | 56 | Triode No. 2 | |
7731 | 6.3 | EV2-6370 | 15 | B | 3 | 57 | Pentode Sect. | |
7731 | 6.3 | EV9-1080 | 16 | C | 3 | 57 | Triode Sect. | |
7732 | 6.3 | ET1-5627 | 11 | D | 3 | 28 | ||
7733 | 12.6 | EV2-7813 | 9 | D | 3 | 46 | ||
7895 | 6.3 | DR4-2080 | 17 | D | 3 | 32 | Use Hickok adapter 1050-127 | |
17GW6 | 20.0 | HS5-0480 | 31 | D | (1) | 38 | Cap=Plate. Make line test at 56 | |
General Notes | ||||||||
Disregard shorts test after GM test is completed. Allow 60 seconds for heater warmup. Allow 5 seconds to obtain Gm readings. | ||||||||
(1) Hold down pushbutton 2-diode and press pushbutton 3-mut. cond. |
2C39 | 6.3 | HS6-5080 | 18 | E | 3 | 50 | TV-7/U,TV-7A/U, TV-7B/U only | |
2C39 | 6.3 | HS6-5080 | 78 | 0 | F | 3 | 50 | Use adapter E107. TV-7D/U only |
2C40 | 6.3 | HS0-0080 | 17 | C | 3 | 35 | Cap connects to plate. Ring connects to grid | |
2C42 | 6.3 | HS0-0080 | 10 | D | 3 | 38 | Cap connects to plate. Ring connects to grid | |
2C43 | 6.3 | HS0-0080 | 17 | C | 3 | 56 | Cap connects to plate. Ring connects to grid | |
2C45 | 7.5 | ER3-2000 | 37 | B | 3 | 55 | ||
2C46 | 6.3 | HS0-0080 | 9 | B | 3 | 24 | Cap connects to plate. Ring connects to grid | |
2C50 | 12.6 | HY1-2030 | 41 | B | 3 | 45 | Triode No. 1 | |
2C50 | 12.6 | HY4-5060 | 41 | B | 3 | 45 | Triode No. 2 | |
2C51 | 6.3 | KR7-6082 | 17 | D | 3 | 26 | Triode No. 1 | |
2C51 | 6.3 | KR3-4028 | 17 | D | 3 | 26 | Triode No. 2 | |
2C52 | 12.6 | HY4-5062 | 15 | B | 3 | 25 | Triode No. 1 | |
2C52 | 12.6 | HY1-2035 | 15 | B | 3 | 25 | Triode No. 2 | |
2C53 | 6.3 | HS5-0080 | 0 | B | 3 | 10 | Cap connects to plate | |
2CW4 | 2.0 | DR4-2080 | 16 | D | 3 | 44 | Use Hickok adapter 1050-127 | |
2CY5 | 2.5 | ET1-5620 | 11 | D | # | 25 | #Hold down pushbutton 2-DIODE and press pushbutton 3-MUT.COND. | |
2D21 | 6.3 | ET1-6025 | # | 90 | A | 4 | 40 | #Should strike between settings 40 and 30 of the BIAS dial |
2EA5 | 2.5 | ET1-5620 | 10 | D | 3 | 26 | ||
2EN5 | 2.0 | ET0-7056 | 0 | 55 | A | 2 | 30 | Diode No.1 |
2EN5 | 2.0 | ET0-2056 | 0 | D | 3 | 49 | Diode No.2 | |
2ER5 | 2.0 | ET2-5670 | 10 | D | 3 | 49 | ||
2E5 | 2.5 | GR5-4030 | 0 | 100 | A | 3 | Eye open | |
2E5 | 2.5 | GR5-4230 | 0 | 100 | A | 3 | Eye closed | |
2E22 | 6.3 | FR3-0240 | 0 | C | 3 | 50 | Caps connects to plate | |
2E24 | 6.3 | HS5-0300 | 35 | C | 3 | 40 | Caps connects to plate. Short on 3 | |
2E25 | 6.3 | HS5-0408 | 0 | C | 3 | 88 | Caps connects to plate | |
2E26 | 6.3 | HS5-0318 | 37 | C | 3 | 44 | Caps connects to plate | |
2E30 | 6.3 | ET1-5602 | 20 | C | 3 | 88 | ||
2E31 | 1.1 | DV4-1200 | 0 | B | # | 10 | #Hold down pushbutton 2-DIODE and press pushbutton 3-MUT.COND. | |
2E32 | 1.1 | DV4-1200 | 0 | B | # | 10 | #Hold down pushbutton 2-DIODE and press pushbutton 3-MUT.COND. | |
2E35 | 1.1 | DV4-1200 | 18 | B | # | 15 | #Hold down pushbutton 2-DIODE and press pushbutton 3-MUT.COND. | |
2E36 | 1.1 | DV4-1200 | 18 | B | # | 15 | #Hold down pushbutton 2-DIODE and press pushbutton 3-MUT.COND. | |
2E41 | 1.1 | EW5-1200 | 20 | B | # | 10 | Pentode section. #Hold down pushbutton 2-DIODE and press pushbutton 3-MUT.COND. | |
2E41 | 1.1 | EW0-3000 | 0 | 0 | A | 2 | 5 | Diode section |
2E42 | 1.1 | EW5-1200 | 20 | B | # | 10 | Pentode section. #Hold down pushbutton 2-DIODE and press pushbutton 3-MUT.COND. | |
2E42 | 1.1 | EW0-3000 | 0 | 0 | A | 2 | 5 | Diode section |
2ES5 | 2.5 | ET2-5010 | 12 | D | 3 | 35 | ||
2EV5 | 2.5 | ET1-5620 | 10 | D | 3 | 43 | ||
2FH5 | 2.5 | ET2-5070 | 13 | D | 3 | 40 | ||
2FQ5 | 2.5 | ET2-5070 | 15 | D | 3 | 42 | ||
2FY5 | 2.5 | ET2-5016 | 14 | D | 3 | 50 | ||
2G21 | 1.1 | EX3-2651 | 53 | 0 | A | 4 | 20 | Heptode sect. |
2G21 | 1.1 | EX3-1000 | 50 | 0 | A | 4 | 40 | Triode sect. |
2G22 | 1.1 | EX3-2651 | 53 | 0 | A | 4 | 20 | Heptode sect. |
2G22 | 1.1 | EX3-1000 | 50 | 0 | A | 4 | 40 | Triode sect. |
2T4 | 2.5 | ET2-1050 | 37 | D | 3 | 25 | ||
2V2 | 2.5 | HS0-0050 | 0 | 45 | A | 4 | 40 | Cap connects to plate. Short on 3 |
2V3 | 2.5 | HS0-0000 | 0 | 68 | A | 4 | 40 | Cap connects to plate |
2W3 | 2.5 | JS0-4000 | 0 | 0 | A | 7 | 40 | |
2X2A | 2.5 | ER0-0000 | 0 | 78 | A | 4 | 40 | Cap connects to plate. Short on 3 |
2Z2 | 2.5 | ER0-2000 | 0 | 0 | A | 7 | 34 | |
TABLE UNDER CONSTRUCTION!. Keep tuned for upgrades. |
6293 | 6.3 | HS5-0310 | 25 | D | 3 | 36 | ||
6540 | 6.3 | DU7-1265 | 10 | D | 3 | 22 | ||
6850 | 12.6 | FT6-0140 | 22 | C | 3 | 56 | Cap above octal pins 2 and 3 connects to plate. Use Hickok adapter 1050-107. Connect negative end of a 30 V battery to pin 2 of the Loctal socket. Connect positive end of the 30 V battery to pin 4 of the Loctal socket | |
6850 | 12.6 | FT2-0140 | 22 | C | 3 | 56 | Cap above octal pins 6 and 7 connects to plate. Connect negative end of a 30 V battery to pin 6 of the Loctal socket. Connect positive end of the 30 V battery to pin 4 of the Loctal socket. *** CAUTION *** Disconnect battery between selector changes | |
6872 | 6.3 | DU7-1265 | 27 | B | 3 | 45 | ||
7308 | 6.3 | EV7-6080 | 21 | D | 3 | 50 | Triode No.1 | |
7308 | 6.3 | EV2-1030 | 21 | D | 3 | 50 | Triode No.2 | |
7868 | 6.3 | EV2-9730 | 10 | D | 3 | 42 | Use Hickok adapter 1050-144 | |
7889 | 25.0 | DW7-8050 | 13 | D | 3 | 13 | Triode No.1 | |
7889 | 25.0 | DW2-1040 | 13 | D | 3 | 13 | Triode No.2 |
5AR4 | 5.0 | JS0-6000 | 0 | 70 | A | 7 | 40 | Plate No.1 |
5AR4 | 5.0 | JS0-4000 | 0 | 70 | A | 7 | 40 | Plate No.2 |
6AR11 | 6.3 | BS4-8937 | 12 | C | 3 | 51 | Pentode No.1 (use Hickok adapter 1704, selectors 4-3-2) | |
6AR11 | 6.3 | BX5-2364 | 12 | C | 3 | 51 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-7) | |
6AU4 | 6.3 | HY0-5030 | 0 | 66 | A | 7 | 40 | |
6B10 | 6.3 | BV3-4020 | 29 | C | 3 | 28 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-5) | |
6B10 | 6.3 | BS5-6070 | 29 | C | 3 | 28 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6B10 | 6.3 | BS0-8090 | 0 | 53 | A | 2 | 40 | Diode No.1 (use Hickok adapter 1704, selectors 0-0-2) |
6B10 | 6.3 | BS0-8090 | 0 | 53 | A | 2 | 40 | Diode No.2 (use Hickok adapter 1704, selectors 8-0-2) |
6BD11 | 6.3 | BT5-2490 | 27 | C | 3 | 38 | Pentode section (use Hickok adapter 1704, selectors 4-5-3) | |
6BD11 | 6.3 | BS6-8050 | 29 | B | 3 | 38 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
6BD11 | 6.3 | BS3-4070 | 24 | B | 3 | 54 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6BF11 | 6.3 | BS8-3490 | 31 | D | 3 | 33 | Pentode No.1 (use Hickok adapter 1704, selectors 4-3-2) | |
6BF11 | 6.3 | BY3-7625 | 26 | B | 3 | 10 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-8) | |
6DQ6B | 6.3 | HS5-0480 | 36 | D | 3 | 30 | Cap connects to plate | |
12BY7A | 12.6 | EV2-7813 | 9 | D | 3 | 46 | ||
866 | 3.0 | ER0-0000 | 0 | 67 | A | 7 | 40 | Cap connects to plate |
6883 | 12.6 | HS5-0318 | 30 | D | 3 | 35 | Cap connects to plate | |
7587 | 6.3 | DR4-0280 | 10 | D | # | 38 | Cap connects to plate. Use Hickok adapter 1050-127. # Hold down push button 2-DIODE and press push button 3-MUT.COND. | |
7788/E810F | 6.3 | EV2-7938 | 29 | C | 3 | 50 | ||
7854 | 12.6 | HR6-0340 | 35 | C | 3 | 60 | Plate No.1 : Use Hickok adapter 1050-107. Connect the negative end of a 30 V battery to pin 2 of the large 7 pin socket. Connect the positive end of the battery to pin 4 of the large 7 pin socket. Connect the plate jack connector to the cap pin over pin 6 of the octal socket. CAUTION: disconnect the battery before changing selector settings. | |
7854 | 12.6 | HR2-0340 | 35 | C | 3 | 60 | Plate No.2 : Use Hickok adapter 1050-107. Connect the negative end of a 30 V battery to pin 6 of the large 7 pin socket. Connect the positive end of the battery to pin 4 of the large 7 pin socket. Connect the plate jack connector to the cap pin over pin 3 of the octal socket. CAUTION: disconnect the battery before changing selector settings. | |
8032 | 12.6 | HS5-0318 | 30 | D | 3 | 35 | Cap connects to plate | |
8077 | 12.6 | EV2-7813 | 9 | D | 3 | 46 |
2DF4 | 2.5 | EV8-3109 | 50 | 52 | A | 3 | 50 | |
2HA5 | 2.0 | ET1-5076 | 30 | B | 3 | 60 | ||
2HM5 | 2.0 | ET1-5076 | 30 | B | 3 | 60 | ||
2HQ5 | 2.0 | ET1-5076 | 30 | B | 3 | 54 | ||
3B22 | 2.5 | ER0-2000 | 0 | 88 | A | 4 | 80 | Diode No.1 |
3B22 | 2.5 | ER0-3000 | 0 | 88 | A | 4 | 80 | Diode No.2 |
4D32 | 6.3 | HR6-0240 | 55 | B | 3 | 33 | Cap=P: Use Hickok adapter 1050-107. CAUTION: with line voltage down, insert tube slowly, adjust line to normal position | |
6AC10 | 6.3 | BT9-2040 | 30 | B | 3 | 28 | Triode No.1 (use Hickok adapter 1704, selectors 2-0-3) | |
6AC10 | 6.3 | BS7-5060 | 30 | B | 3 | 28 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6AC10 | 6.3 | BV4-2030 | 30 | B | 3 | 28 | Triode No.3 (use Hickok adapter 1704, selectors 0-4-5) | |
6AD10 | 6.3 | BU8-3290 | 37 | B | 3 | 51 | Pentode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
6AD10 | 6.3 | BU3-7625 | 18 | B | 3 | 32 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-4) | |
6AF9 | 6.3 | FW8-1970 | 29 | B | 3 | 58 | Pentode No.1 (use Hickok adapter 1704, selectors 1-0-0) | |
6AF9 | 6.3 | FW1-4320 | 28 | B | 3 | 44 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-0) | |
6AF11 | 6.3 | BV4-2390 | 20 | C | 3 | 63 | Pentode section (use Hickok adapter 1704, selectors 3-4-5) | |
6AF11 | 6.3 | BS6-8050 | 27 | B | 3 | 55 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
6AF11 | 6.3 | BS3-4070 | 20 | B | 3 | 55 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6AG11 | 6.3 | BS8-7090 | 30 | B | 3 | 42 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
6AG11 | 6.3 | BS5-6040 | 30 | B | 3 | 42 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6AG11 | 6.3 | BU0-2030 | 0 | 60 | A | 2 | 35 | Diode No.1 (use Hickok adapter 1704, selectors 2-3-4) |
6AG11 | 6.3 | BU0-3020 | 0 | 60 | A | 2 | 35 | Diode No.2 (use Hickok adapter 1704, selectors 0-0-4) |
6AL11 | 6.3 | BU8-3290 | 35 | B | 3 | 62 | Pentode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
6AL11 | 6.3 | BV3-6724 | 8 | B | 3 | 18 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-5) | |
6U4 | 6.3 | HY0-5030 | 0 | 66 | A | 7 | 40 | |
6AV11 | 6.3 | BT9-2040 | 24 | B | 3 | 56 | Triode No.1 (use Hickok adapter 1704, selectors 2-0-3) | |
6AV11 | 6.3 | BS7-5060 | 24 | B | 3 | 56 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6AV11 | 6.3 | BV4-2030 | 24 | B | 3 | 56 | Triode No.3 (use Hickok adapter 1704, selectors 0-4-5) | |
6AX3 | 6.3 | BS0-4070 | 0 | 54 | A | 7 | 40 | Use Hickok adapter 1704, set adapter selectors to 0-0-2) |
6AY3 | 6.3 | EV0-2090 | 0 | 38 | A | 7 | 50 | Use Hickok adapter 1704, set adapter selectors to 0-0-0) |
6AY11 | 6.3 | BS8-7090 | 20 | B | 3 | 26 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
6AY11 | 6.3 | BS5-6040 | 20 | B | 3 | 26 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6AY11 | 6.3 | BU0-2030 | 0 | 60 | A | 2 | 35 | Diode No.1 (use Hickok adapter 1704, selectors 2-3-4) |
6AY11 | 6.3 | BU0-3020 | 0 | 60 | A | 2 | 35 | Diode No.2 (use Hickok adapter 1704, selectors 0-0-4) |
6B10 | 6.3 | BS0-8090 | 0 | 53 | A | 2 | 40 | Diode No.1 (use Hickok adapter 1704, selectors 8-0-2) |
6BA11 | 6.3 | BS4-6387 | 10 | B | 3 | 19 | Pentode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
6BA11 | 6.3 | BW4-2385 | 10 | B | 3 | 19 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-6) | |
6BA11 | 6.3 | BU9-3020 | 33 | B | 3 | 45 | Triode section (use Hickok adapter 1704, selectors 2-3-4) | |
6BH11 | 6.3 | BU8-2930 | 19 | C | 3 | 38 | Pentode section (use Hickok adapter 1704, selectors 2-3-4) | |
6BH11 | 6.3 | BS6-7050 | 13 | D | 3 | 42 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
6BH11 | 6.3 | BV4-3020 | 13 | D | 3 | 42 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-5) | |
6BK4 | 6.3 | HS0-5010 | 0 | 70 | A | 2 | 17 | |
6BS3 | 6.3 | EV0-2090 | 0 | 60 | A | 7 | 42 | Use Hickok adapter 1704, selectors 0-0-0 |
6BW11 | 6.3 | BU3-8927 | 10 | D | 3 | 30 | Pentode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
6BW11 | 6.3 | BX3-5426 | 26 | B | 3 | 52 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-7) | |
6C10 | 6.3 | BT9-2040 | 12 | B | 3 | 32 | Triode No.1 (use Hickok adapter 1704, selectors 2-0-3) | |
6C10 | 6.3 | BS7-5060 | 12 | B | 3 | 32 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6C10 | 6.3 | BV4-2030 | 12 | B | 3 | 32 | Triode No.3 (use Hickok adapter 1704, selectors 0-4-5) | |
6CJ3 | 6.3 | EV0-2090 | 0 | 70 | A | 7 | 40 | Use Hickok adapter 1704, selectors 0-0-0 |
6D10 | 6.3 | BT9-2040 | 29 | B | 3 | 34 | Triode No.1 (use Hickok adapter 1704, selectors 2-0-3) | |
6D10 | 6.3 | BS7-5060 | 29 | B | 3 | 34 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6D10 | 6.3 | BV4-2030 | 29 | B | 3 | 34 | Triode No.3 (use Hickok adapter 1704, selectors 0-4-5) | |
6DW4 | 6.3 | EV0-2090 | 0 | 66 | A | 7 | 40 | Use Hickok adapter 1704, selectors 0-0-0 |
6EH4 | 6.3 | BS0-6050 | 0 | 70 | A | 2 | 17 | Cap=G. Use Hickok adapter 1704, selectors 0-0-2 |
6GE5 | 6.3 | BV4-7230 | 36 | D | 3 | 30 | Use Hickok adapter 1704, selectors 3-4-5 | |
6CJ7 | 6.3 | EV2-6710 | 25 | B | 3 | 60 | Pentode section | |
6CJ7 | 6.3 | EV9-8030 | 40 | B | 3 | 44 | Triode section | |
6GV5 | 6.3 | BU9-0320 | 36 | D | 3 | 30 | Cap=Plate. Use Hickok adapter 1704, selectors 2-3-4 | |
6HA5 | 6.3 | ET1-5076 | 30 | B | 3 | 60 | ||
6HM5 | 6.3 | ET1-5076 | 30 | B | 3 | 60 | ||
6HQ5 | 6.3 | ET1-5076 | 30 | B | 3 | 54 | ||
6J11 | 6.3 | BU3-9782 | 26 | B | 3 | 52 | Pentode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
6J11 | 6.3 | BX5-3264 | 26 | B | 3 | 52 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-7) | |
6JB6 | 6.3 | EV2-0138 | 34 | D | # | 38 | Cap=Plate. Use Hickok adapter 1704, selectors 0-0-0. #Hold down push button 2-DIODE and press button 3-MUT.COND. | |
6JE6 | 6.3 | EV2-0738 | 53 | D | 3 | 34 | Cap=Plate. Use Hickok adapter 1704, selectors 0-0-0 | |
6JF6 | 6.3 | EV2-0138 | 55 | D | 3 | 45 | Cap=Plate. Use Hickok adapter 1704, selectors 0-0-0 | |
6JM6 | 6.3 | BW5-0324 | 48 | D | 3 | 32 | Cap=Plate. Use Hickok adapter 1704, selectors 4-0-6 | |
6JN6 | 6.3 | BW5-7324 | 48 | D | 3 | 32 | Use Hickok adapter 1704, selectors 0-5-6 | |
6JS6 | 6.3 | BW5-0324 | 82 | C | 3 | 52 | Cap=Plate. Use Hickok adapter 1704, selectors 0-0-6 | |
6JU8 | 6.3 | EV0-8090 | 0 | 70 | A | 2 | 40 | Diode No.1 |
6JU8 | 6.3 | EV0-7080 | 0 | 70 | A | 2 | 40 | Diode No.2 |
6JU8 | 6.3 | EV0-2030 | 0 | 70 | A | 2 | 40 | Diode No.3 |
6JU8 | 6.3 | EV0-1020 | 0 | 70 | A | 2 | 40 | Diode No.4 |
6K11 | 6.3 | BT9-2048 | 24 | B | 3 | 56 | Triode No.1 (use Hickok adapter 1704, selectors 2-0-3) | |
6K11 | 6.3 | BS7-5068 | 12 | B | 3 | 32 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6K11 | 6.3 | BV4-2038 | 12 | B | 3 | 32 | Triode No.3 (use Hickok adapter 1704, selectors 0-4-5) | |
6KT6 | 6.3 | EV2-7819 | 22 | C | 3 | 52 | ||
6KT8 | 6.3 | EV7-9860 | 15 | C | 3 | 57 | Pentode section | |
6KT8 | 6.3 | EV2-3010 | 26 | B | 3 | 38 | Triode section | |
6LC6 | 6.3 | HS0-5061 | 0 | 70 | A | 2 | 17 | Cap=Grid |
6LF6 | 6.3 | BW5-0324 | 70 | D | 3 | 38 | Cap=Plate. Use Hickok adapter 1704, selectors 0-0-6 | |
6LQ8 | 6.3 | EV7-9860 | 32 | B | 3 | 40 | Pentode section | |
6LQ8 | 6.3 | EV2-3010 | 33 | B | 3 | 35 | Triode section | |
6Q11 | 6.3 | BT9-2048 | 24 | B | 3 | 56 | Triode No.1 (use Hickok adapter 1704, selectors 2-0-3) | |
6Q11 | 6.3 | BS7-5068 | 12 | B | 3 | 32 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
6Q11 | 6.3 | BV4-2038 | 12 | B | 3 | 32 | Triode No.3 (use Hickok adapter 1704, selectors 0-4-5) | |
6T10 | 6.3 | BU8-3290 | 35 | B | 3 | 62 | Pentode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
6T10 | 6.3 | BU3-7625 | 8 | B | 3 | 18 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-4) | |
7GV7 | 7.5 | EV7-3280 | 29 | B | 3 | 33 | Pentode section | |
7GV7 | 7.5 | EV9-1080 | 38 | C | 3 | 47 | Triode section | |
7HG8 | 7.5 | EV2-8930 | 25 | ? | 3 | 55 | Pentode section | |
7HG8 | 7.5 | EV6-7030 | 44 | ? | 3 | 30 | Triode section | |
8A8 | 10.0 | EV2-6371 | 19 | C | 3 | 34 | Pentode section | |
8A8 | 10.0 | EV9-1086 | 34 | C | 3 | 36 | Triode section | |
8AR11 | 7.5 | BS4-8937 | 12 | C | 3 | 51 | Pentode No.1 (use Hickok adapter 1704, selectors 4-3-2) | |
8AR11 | 7.5 | BX5-2364 | 12 | C | 3 | 51 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-7) | |
8BA11 | 7.5 | BS4-6387 | 10 | B | 3 | 19 | Pentode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
8BA11 | 7.5 | BW4-2385 | 10 | B | 3 | 19 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-6) | |
8BA11 | 7.5 | BU9-3020 | 33 | B | 3 | 45 | Triode section (use Hickok adapter 1704, selectors 2-3-4) | |
8BM11 | 7.5 | BU3-7928 | 20 | C | 3 | 40 | Pentode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
8BM11 | 7.5 | BX6-2354 | 25 | C | 3 | 31 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-7) | |
9A8 | 10.0 | EV2-6371 | 19 | C | 3 | 34 | Pentode section | |
9A8 | 10.0 | EV9-1086 | 34 | C | 3 | 36 | Triode section | |
9KZ8 | 10.0 | EV2-6370 | 19 | C | 3 | 38 | Pentode section | |
9KZ8 | 10.0 | EV9-1080 | 13 | D | 3 | 42 | Triode section | |
10JA8 | 10.0 | EV7-9860 | 27 | C | 3 | 32 | Tetrode section | |
10JA8 | 10.0 | EV2-3010 | 27 | B | 3 | 39 | Triode section | |
10JY8 | 10.0 | EV7-9860 | 20 | C | 3 | 63 | Pentode section | |
10JY8 | 10.0 | EV2-3010 | 33 | B | 3 | 35 | Triode section | |
11AR11 | 10.0 | BS4-8937 | 12 | C | 3 | 51 | Pentode No.1 (use Hickok adapter 1704, selectors 4-3-2) | |
11AR11 | 10.0 | BX5-2364 | 12 | C | 3 | 51 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-7) | |
11BQ11 | 10.0 | BS4-8937 | 12 | C | 3 | 51 | Pentode No.1 (use Hickok adapter 1704, selectors 4-3-2) | |
11BQ11 | 10.0 | BX5-2364 | 26 | B | 3 | 52 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-7) | |
11BT11 | 10.0 | BV4-2386 | 32 | B | 3 | 45 | Pentode section (use Hickok adapter 1704, selectors 3-4-5) | |
11BT11 | 10.0 | BS5-7060 | 23 | C | 3 | 29 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
11BT11 | 10.0 | BS3-9040 | 20 | C | 3 | 43 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
11CA11 | 10.0 | BU8-3297 | 30 | C | 3 | 37 | Pentode section (use Hickok adapter 1704, selectors 2-3-4) | |
11CA11 | 10.0 | BS6-4050 | 25 | C | 3 | 45 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
11CA11 | 10.0 | BU3-2070 | 23 | C | 3 | 29 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-4) | |
11FY7 | 10.0 | BU2-3090 | 22 | B | 3 | 20 | Triode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
11FY7 | 10.0 | BS3-5070 | 54 | D | 3 | 38 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
11HM7 | 10.0 | EV2-7819 | 13 | D | 3 | 61 | ||
11LQ8 | 10.0 | EV7-9860 | 32 | B | 3 | 40 | Pentode section | |
11LQ8 | 10.0 | EV2-3010 | 33 | B | 3 | 35 | Triode section | |
11LT8 | 10.0 | EV9-3216 | 10 | D | 3 | 38 | Pentode section | |
11LT8 | 10.0 | EV0-8070 | 0 | 70 | A | 2 | 40 | Diode No.1 |
11LT8 | 10.0 | EV0-6070 | 0 | 70 | A | 2 | 40 | Diode No.2 |
12AX3 | 12.6 | BS0-4070 | 0 | 54 | A | 7 | 40 | Use Hickok adapter 1704, selectors 0-0-2 |
12BF11 | 12.6 | BS8-3490 | 31 | D | 3 | 33 | Pentode No.1 (use Hickok adapter 1704, selectors 4-3-2) | |
12BF11 | 12.6 | BY3-7625 | 26 | B | 3 | 10 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-8) | |
12BS3 | 12.6 | EV0-2090 | 0 | 60 | A | 7 | 42 | Use Hickok adapter 1704, selectors 0-0-0 |
12T10 | 12.6 | BU8-3290 | 35 | B | 3 | 62 | Pentode No.1 (use Hickok adapter 1704, selectors 2-3-4) | |
12T10 | 12.6 | BU3-7625 | 8 | B | 3 | 18 | Pentode No.2 (use Hickok adapter 1704, selectors 0-0-4) | |
14BL11 | 12.6 | BV4-2380 | 32 | B | 3 | 45 | Pentode section (use Hickok adapter 1704, selectors 3-4-5) | |
14BL11 | 12.6 | BS5-7060 | 23 | C | 3 | 29 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
14BL11 | 12.6 | BS3-9040 | 20 | C | 3 | 43 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
14BR11 | 12.6 | BW2-5340 | 27 | C | 3 | 38 | Pentode section (use Hickok adapter 1704, selectors 0-5-6) | |
14BR11 | 12.6 | BS8-6050 | 29 | B | 3 | 38 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
14BR11 | 12.6 | BT2-9070 | 24 | B | 3 | 54 | Triode No.2 (use Hickok adapter 1704, selectors 2-0-3) | |
15AF11 | 12.6 | BS6-8050 | 27 | B | 3 | 55 | Triode No.1 (use Hickok adapter 1704, selectors 0-0-2) | |
15AF11 | 12.6 | BS3-4070 | 20 | B | 3 | 55 | Triode No.2 (use Hickok adapter 1704, selectors 0-0-2) | |
15BD11 | 12.6 | BV4-2390 | 27 | C | 3 | 38 | Pentode section. MAKE LINE TEST AT 64. Use Hickok adapter 1704, selectors 3-4-5 | |
15BD11 | 12.6 | BS6-8050 | 29 | B | 3 | 38 | Triode No.1. MAKE LINE TEST AT 64. Use Hickok adapter 1704, selectors 0-0-2 | |
15BD11 | 12.6 | BS3-4070 | 24 | B | 3 | 54 | Triode No.2. MAKE LINE TEST AT 64 .Use Hickok adapter 1704, selectors 0-0-2 | |
17AX3 | 20.0 | BS0-4070 | 0 | 54 | A | 7 | 40 | MAKE LINE TEST AT 56. Use Hickok adapter 1704, selectors 0-0-2 |
17BE3 | 20.0 | BT0-2070 | 0 | 66 | A | 7 | 40 | MAKE LINE TEST AT 56. Use Hickok adapter 1704, selectors 2-0-3 |
17BF11 | 20.0 | BU8-3290 | 31 | D | 3 | 33 | Pentode No.1. MAKE LINE TEST AT 56. Use Hickok adapter 1704, selectors 2-3-4 | |
17BF11 | 20.0 | BU3-7625 | 26 | B | 3 | 10 | Pentode No.2. MAKE LINE TEST AT 56. Use Hickok adapter 1704, selectors 0-0-4 | |
17BS3 | 20.0 | EV0-2090 | 0 | 60 | A | 7 | 42 | MAKE LINE TEST AT 56. Use Hickok adapter 1704, selectors 0-0-0 |
17GV5 | 20.0 | BU9-3020 | 36 | D | 3 | 30 | Cap=P. MAKE LINE TEST AT 56. Use Hickok adapter 1704, selectors 2-3-4 | |
866 | 3.0 | ER0-0000 | 0 | 67 | A | 7 | 40 | Cap connects to Plate |
6384 | 6.3 | GY7-3510 | 34 | D | 3 | 27 | ||
6850 | 12.6 | FT6-0140 | 22 | C | 3 | 56 | Cap above octal pins 2 and 3 connects to plate. Use Hickok adapter 1050-107. Connect negative (-) end of a 30V battery to pin 2 of the Loctal socket | |
6850 | 12.6 | FT2-0140 | 22 | C | 3 | 56 | Cap above octal pins 6 and 7 connects to plate. Use Hickok adapter 1050-107. Connect negative (-) end of a 30V battery to pin 6 of the Loctal socket. Connect positive (+) end of the 20V battery (Eveready 413) to pin 4 of the Loctal socket for each test. CAUTION: disconnect battery between selector changes | |
7289 | 6.3 | HS6-5080 | 18 | E | 3 | 50 | TV-7/U, TV-7A/U, TV-7B/U Use adapter E107 | |
7289 | 6.3 | HS6-5080 | 78 | F | 3 | 50 | TV-D7/U Use adapter E107 | |
7587 | 6.3 | DR4-0280 | 10 | D | # | 38 | Cap connects to plate. Use Hickok adapter 1050-127. #Hold down push button 2-DIODE and press push button 3-MUT.COND. | |
7788 E810F | 6.3 | EV2-7938 | 29 | C | 3 | 50 | ||
7854 | 12.6 | HR6-0340 | 35 | C | 3 | 60 | Plate No.1 Use Hickok adapter 1050-107. Connect the negative end of a 30V battery to pin 2 of the large 7.pin socket. Connect the positive end of the battery to pin 4 of the large 7-pin socket. Connect the plate jack connector to the cap pin over pin 6 of the octal socket | |
7854 | 12.6 | HR2-0340 | 35 | C | 3 | 60 | Plate No.2 Use Hickok adapter 1050-107. Connect the negative end of a 30V battery to pin 6 of the large 7.pin socket. Connect the positive end of the battery to pin 4 of the large 7-pin socket. Connect the plate jack connector to the cap pin over pin 3 of the octal socket. CAUTION: disconnect the battery before changing selector settings | |
7889 | 25.0 | DW2-1004 | 13 | D | 3 | 13 | Triode No.2 | |
7905 | 6.3 | BZ2-6307 | 50 | 47 | A | 3 | 50 | |
7984 | 12.6 | BS3-5678 | 45 | D | 3 | 27 | Use Hickok adapter 1704, selectors 5-0-4 | |
8077 | 12.6 | EV2-7813 | 9 | D | 3 | 46 | ||
8532 | 6.3 | ET1-7020 | 15 | D | 3 | 45 | ||
The following tubes CANNOT BE TESTED for the reasons stated:
5783WA - voltage reference tube. Model TV-7/U not suitable 5960 - required voltage and current not available in TV-7/U 6528 - too high powered to test 6798 - TR tube. Model TV-7/U not suitable 7077 - ceramic metal planar triode. Requires adapter not available 7815 - tube rated for pulse operations. Model TV-7/U not suitable |
1. PURPOSE: This supplement is issued to change a filament in Data Table |
2. INSTRUCTIONS: Page 19, Tube Type 6AU8: Change Filament 6.8 to 6.3 (Pentode sect.) |
1. PURPOSE: The purpose of this supplement is to ammend the basic publication |
2. INSTRUCTIONS: Page 39, on second line change tube type 13BE6 to 12BE6 |
1. LIST OF AFFECTED PAGES IN BASIC MANUAL: 71 |
2. SUPPLEMENTAL INFORMATION: Page 71, change first line, Tube Type Number '6320' to read '6360' |
1. LIST OF AFFECTED PAGES IN BASIC MANUAL: 70 |
2. SUPPLEMENTAL INFORMATION: Page 70, DATA TABLE, after Tube Type 6293 add the following: |
6336 | 6.3 | HY4-5062 | 100 | C | 3 | 36 | Triode No.1 | |
6336 | 6.3 | HY1-2035 | 100 | C | 3 | 36 | Triode No.2 |
Page 48A, Chart under paragraph 36, Step 2, second column 'Equipment under test control settings' is ammended as follows: No change from end of Step 1, except: Selector switches: Grid: 5 Plate: 3 Screen: 4 Cathode: 6 Suppressor: 0 Function switch: A |
