New
Tubedata for TV-7 - to use only with Expansion-Box |
Tube Type |
Fil. Voltage |
Selector Positions |
Bias |
Shunt |
Range |
Press to Test |
Minimum Value |
Socket in-box |
Notations |
1701 |
2 (Uf=1,8V) |
BT0-2010 |
0 |
45 |
A |
7 |
50 |
Diode #1; set line adjust to 59 |
1701 |
BT0-4010 |
0 |
45 |
A |
7 |
50 |
Diode #2; set line adjust to 59 |
ABC1 |
4,3 |
CT0-5040 |
0 |
40 |
A |
7 |
30 |
Au |
Diode #1 |
ABC1 |
4,3 |
CT0-6040 |
0 |
40 |
A |
7 |
30 |
Au |
Diode #2 |
ABC1 |
4,3 |
CT0-8040 |
25 |
0 |
C |
3 |
40 |
Au |
Triode system |
ACH1 |
4,3 (Uf=4V) |
CT6-5010 |
30 |
0 |
B |
3 |
40 |
Hx |
Triode sytem; set
line adjust to 58 |
ACH1 |
4,3 (Uf=4V) |
CT0-7416 |
20 |
0 |
C |
3 |
20 |
Hx |
Hexode System; use
cable to 'G'; set line adjust to 58 |
AF7 |
4,3 |
CT0-8745 |
20 |
0 |
C |
3 |
30 |
Use cable to 'G' |
AL1 |
4,3 |
CT6-8720 |
25 |
0 |
C |
3 |
50 |
Au |
AZ1 |
CT0-5020 |
0 |
30 |
A |
7 |
50 |
St |
Diode #1 |
AZ1 |
4,3 |
CT0-8020 |
0 |
30 |
A |
7 |
50 |
St |
Diode #2 |
AZ11 |
CT0-7020 |
0 |
30 |
A |
7 |
40 |
St |
Diode #1 |
AZ11 |
4,3 |
CT0-5020 |
0 |
30 |
A |
7 |
40 |
St |
Diode #2 |
Ba |
3 (Uf=3,5V) |
CV3-1050 |
20 |
0 |
B |
3 |
30 |
St |
Set line adjust to 63; Post (5-pol)- to St-Adapter |
Bi |
4,3 (Uf=4V) |
CX4-1050 |
20 |
0 |
B |
3 |
50 |
St |
Set line adjust to
58; Post- to St-Adapter |
C3b |
4,3 (Uf=4V) |
CX0-1350 |
25 |
0 |
C |
3 |
30 |
St |
Post- to St-Adapter; use cable to 'G'; set line adjust to 58 |
E2c |
20 (Uf=18V) |
CX4-1350 |
30 |
0 |
D |
3 |
55 |
St |
set line adjust to 57 |
EBL1 |
6,3 |
CT0-6040 |
0 |
20 |
A |
7 |
20 |
Au |
Diode #1 |
EBL1 |
6,3 |
CT0-5040 |
0 |
20 |
A |
7 |
20 |
Au |
Diode #2 |
EBL1 |
6,3 |
CT0-8240 |
20 |
0 |
C |
3 |
10 |
Au |
Pentode system;use
cable to 'G' |
ECL11 |
6,3 |
CT8-7090 |
15 |
0 |
B |
3 |
36 |
St |
Triode system; Plug
noval contact into noval socket |
ECL11 |
6,3 |
CT5-1490 |
30 |
0 |
C |
3 |
56 |
St |
Hept.system; Plug
Ed |
4,3 (Uf=4V) |
CX4-1020 |
40 |
0 |
D |
3 |
45 |
St |
Set line adjust to
EL12 |
6,3 |
CT8-5790 |
25 |
0 |
D |
3 |
46 |
St |
Plug noval contact in
noval socket |
EL156 |
6,3 |
CT8-5690 |
25 |
0 |
D |
3 |
50 |
St |
noval socket |
EL50 |
6,3 |
CT6-1745 |
25 |
0 |
D |
3 |
40 |
Au |
Use cable to 'P' |
EL509 |
6,3 |
EV1-5392 |
30 |
0 |
E |
3 |
40 |
Mag |
Use cable to 'P' |
EL51 |
6,3 |
CT6-5740 |
25 |
0 |
D |
3 |
36 |
Au |
noval socket |
GU50 (Russ) |
12,6 |
EY2-6315 |
40 |
0 |
D |
3 |
40 |
GU |
KL2 |
2 |
CT6-8720 |
35 |
0 |
C |
3 |
40 |
Au |
PL504 |
25 (Uf=27V) |
EV1-6180 |
40 |
0 |
D |
3 |
40 |
Mn |
Set line adjust to 62 |
RE084 |
4 |
BT2-4010 |
30 |
0 |
B |
3 |
10 |
Eu |
RE134 |
4 |
BT2-4010 |
40 |
0 |
B |
3 |
15 |
Eu |
RG12D60 |
12,6 |
CT0-5040 |
0 |
25 |
A |
7 |
50 |
P2000 |
Diode #1 |
RG12D60 |
12,6 |
CT0-6040 |
0 |
25 |
A |
7 |
50 |
P2000 |
Diode #2 |
RV12P2000 |
12,6 |
CT7-6541 |
25 |
0 |
A |
3 |
34 |
P2000 |
RV12P2001 |
12,6 |
CT7-6541 |
25 |
0 |
A |
3 |
46 |
P2000 |
UCL11 |
75 (Uf=60V) |
CT8-7090 |
15 |
0 |
B |
3 |
32 |
St |
Triode system; set
line adjust to 49; plug noval contact into noval socket |
UCL11 |
CT5-1490 |
35 |
0 |
C |
3 |
45 |
St |
Hept.system; set line
UEL51 |
75 (Uf=62V) |
CT8-6790 |
20 |
0 |
B |
3 |
36 |
St |
System1; plug noval
contact in noval socket; set line adjust to 50 |
UEL51 |
CT5-1490 |
25 |
0 |
D |
3 |
30 |
St |
System2; plug noval
VCL11 |
117 (Uf=90V) |
CT8-7790 |
20 |
0 |
B |
3 |
30 |
St |
Triode sytem; set
line adjust to 48; plug noval contact into noval socket; s.line.adj.to 48 |
VCL11 |
CT5-1490 |
20 |
0 |
C |
3 |
40 |
St |
VY2 |
35 (Uf=30V) |
CT0-5040 |
0 |
40 |
A |
7 |
40 |
Mini-Au |
Set line adjust to 48 |
