| Tubedata for TV-7� (Rimlock-Tubes) | ||||||||||
| Tube Type | Fil. Voltage | Selector Positions | Bias | Shunt | Range | Press to Test | Minimum Value | Notations | ||
| AZ41 | 4,3 (Uf = 4V) | HY0-6070 | 0 | 20 | A | 7 | 30 | Diode #1, Set line adjust to 54 | ||
| AZ41 | 4,3 (Uf = 4V) | HY0-2070 | 0 | 20 | A | 7 | 30 | Diode #2, Set line adjust to 54 | ||
| EAF42 | 6,3 | BY0-3070 | 0 | 0 | A | 7 | 12 | Diode section | ||
| EAF42 | 6,3 | BY6-2574 | 15 | 0 | C | 3 | 35 | Pentode Section | ||
| EB41 | 6,3 | BY0-6070 | 0 | 60 | A | 7 | 44 | Diode #1 | ||
| EB41 | 6,3 | BY0-4030 | 0 | 60 | A | 7 | 44 | Diode #2 | ||
| EBC41 | 6,3 | BY0-6070 | 0 | 0 | A | 7 | 10 | Diode #1 | ||
| EBC41 | 6,3 | BY0-5070 | 0 | 0 | A | 7 | 10 | Diode #2 | ||
| EBC41 | 6,3 | BY3-2070 | 15 | 0 | B | 3 | 38 | Triode section | ||
| ECC40 | 6,3 | BY3-2040 | 20 | 0 | C | 3 | 36 | Triode #1 | ||
| ECC40 | 6,3 | BY6-5070 | 20 | 0 | C | 3 | 36 | Triode #2 | ||
| ECH42 | 6,3 | BY4-3070 | 15 | 0 | B | 3 | 40 | Triode section | ||
| ECH42 | 6,3 | BY6-2574 | 15 | 0 | C | 3 | 30 | Heptode section | ||
| ECH43 | 6,3 | BY4-3070 | 25 | 0 | C | 3 | 30 | Triode section | ||
| ECH43 | 6,3 | BY6-2574 | 25 | 0 | C | 3 | 30 | Heptode section | ||
| ECL113 | 6,3 | BY4-3570 | 15 | 0 | D | 3 | 36 | Pentode section | ||
| ECL113 | 6,3 | BY6-2570 | 10 | 0 | B | 3 | 40 | Triode section | ||
| EF40 | 6,3 | BY5-2674 | 20 | 0 | B | 3 | 45 | |||
| EF41 | 6,3 | BY6-2570 | 15 | 0 | C | 3 | 30 | |||
| EF42 | 6,3 | BY6-2574 | 15 | 0 | C | 3 | 32 | |||
| EF43 | 6,3 | BY6-2574 | 20 | 0 | C | 3 | 42 | |||
| EL41 | 6,3 | BY6-2570 | 30 | 0 | C | 3 | 48 | |||
| EL42 | 6,3 | BY6-2570 | 30 | 0 | C | 3 | 40 | |||
| EZ40 | 6,3 | BY0-6070 | 0 | 40 | A | 7 | 44 | Diode #1 | ||
| EZ40 | 6,3 | BY0-2070 | 0 | 40 | A | 7 | 44 | Diode #2 | ||
| EZ41 | 6,3 | BY0-6070 | 0 | 40 | A | 7 | 36 | Diode #1 | ||
| EZ41 | 6,3 | BY0-2070 | 0 | 40 | A | 7 | 36 | Diode #2 | ||
| UAF41 | 12,6 | BY0-3070 | 0 | 0 | A | 7 | 10 | Diode section | ||
| UAF41 | 12,6 | BY6-2570 | 15 | 0 | C | 3 | 30 | Pentode Section | ||
| UAF42 | 12,6 | see EAF 42 | ||||||||
| UBC41 | 12,6 | Set line adjust to 65, see EBC41 | ||||||||
| UCH42 | 12,6 (Uf = 14V) | Set line adjust to 64, see ECH42 | ||||||||
| UF41 | 12,6 | see EF41 | ||||||||
| UF42 | 20 (Uf = 21V) | Set line adjust to 61, see EF42 | ||||||||
| UF43 | 20 (Uf = 21V) | Set line adjust to 61, see EF43 | ||||||||
| UL41 | 50 (Uf = 45V) | BY6-2570 | 20 | 0 | D | 3 | 28 | Set line adjust to 50, Value = 38 for new tubes | ||
